Hey !
Im very new to Kicad, and i need some help to solve my DRC.
I have a thousand clearance errors and im not sure how to solve it.
Ive added a picture and the drc log.
Would really appreciate your help!
** Found 32 DRC violations **
[clearance]: Clearance violation (netclass ‘Power’ clearance 0,2000 mm; actual 0,0000 mm)
Rule: netclass ‘Power’; Severity: error
@(165,5700 mm, 55,3000 mm): Track [GND] on F.Cu, length 0,6259 mm
@(-4,3200 mm, -3,8500 mm): Polygon on F.Cu
@(165,5700 mm, 55,9259 mm): Track [GND] on F.Cu, length 0,6260 mm
[clearance]: Clearance violation (netclass ‘Power’ clearance 0,2000 mm; actual 0,1506 mm)
@(157,0108 mm, 56,5519 mm): Track [GND] on F.Cu, length 1,8105 mm
@(4,3200 mm, -3,8500 mm): Polygon on F.Cu
@(156,9300 mm, 55,3000 mm): Track [GND] on F.Cu, length 1,1712 mm
@(165,5700 mm, 55,9259 mm): Track [GND] on F.Cu, length 0,7156 mm
[clearance]: Clearance violation (netclass ‘Power’ clearance 0,2000 mm; actual 0,0662 mm)
@(156,9300 mm, 56,4712 mm): Track [GND] on F.Cu, length 0,0001 mm
@(157,0108 mm, 56,5519 mm): Track [GND] on F.Cu, length 1,3692 mm
@(156,9301 mm, 56,4712 mm): Track [GND] on F.Cu, length 0,1141 mm
[clearance]: Clearance violation (netclass ‘Power’ clearance 0,2000 mm; actual 0,1469 mm)
@(165,5700 mm, 56,5519 mm): Track [GND] on F.Cu, length 1,6617 mm
[clearance]: Clearance violation (netclass ‘Power’ clearance 0,2000 mm; actual 0,1690 mm)
@(165,0640 mm, 56,4319 mm): Track [GND] on F.Cu, length 1,0640 mm
@(165,5700 mm, 51,5000 mm): Track [GND] on B.Cu, length 0,6259 mm
@(-4,3200 mm, -0,0500 mm): Polygon on B.Cu
@(156,9300 mm, 51,5000 mm): Track [GND] on B.Cu, length 3,8000 mm
@(4,3200 mm, -3,8500 mm): Polygon on B.Cu
@(165,5700 mm, 52,1259 mm): Track [GND] on B.Cu, length 3,1741 mm
@(-4,3200 mm, -3,8500 mm): Polygon on B.Cu
[clearance]: Clearance violation (netclass ‘Power’ clearance 0,2000 mm; actual 0,1544 mm)
@(163,0575 mm, 54,0406 mm): Track [/VBUS] on F.Cu, length 2,8650 mm
[clearance]: Clearance violation (netclass ‘Power’ clearance 0,2000 mm; actual 0,1225 mm)
@(165,9225 mm, 54,0406 mm): Track [/VBUS] on F.Cu, length 6,7524 mm
@(165,5700 mm, 55,3000 mm): PTH pad S1 [GND] of USB-C1
@(156,9300 mm, 55,3000 mm): PTH pad S2 [GND] of USB-C1
@(165,5700 mm, 51,5000 mm): PTH pad S3 [GND] of USB-C1
@(-4,3200 mm, -0,0500 mm): Polygon on F.Cu
@(156,9300 mm, 51,5000 mm): PTH pad S4 [GND] of USB-C1
@(4,3200 mm, -0,0500 mm): Polygon on F.Cu
@(4,3200 mm, -0,0500 mm): Polygon on B.Cu
[starved_thermal]: Thermal relief connection to zone incomplete (zone min spoke count 2; actual 1)
Local override; Severity: error
@(124,0000 mm, 47,5000 mm): Zone [GND] on F.Cu and 1 more
@(177,5950 mm, 68,3900 mm): PTH pad 6 [GND] of J1
[solder_mask_bridge]: Front solder mask aperture bridges items with different nets
Rule: board setup solder mask min width; Severity: error
@(-4,3200 mm, -3,9500 mm): Polygon on F.Mask
@(-4,3200 mm, -0,1500 mm): Polygon on F.Mask
@(4,3200 mm, -3,9500 mm): Polygon on F.Mask
@(4,3200 mm, -0,1500 mm): Polygon on F.Mask
[solder_mask_bridge]: Rear solder mask aperture bridges items with different nets
@(-4,3200 mm, -3,9500 mm): Polygon on B.Mask
@(-4,3200 mm, -0,1500 mm): Polygon on B.Mask
@(4,3200 mm, -3,9500 mm): Polygon on B.Mask
@(4,3200 mm, -0,1500 mm): Polygon on B.Mask
** Found 0 unconnected pads **
** Found 0 Footprint errors **
** End of Report **
