Is there any plugin, library or software with which I can add capabilities and when I pass a gerber file, will it tell me if it has errors?
Best regards
Best regards
To you want to check some boundaries, minimal track width and minimal drills?
Thank you, I have seen but fail with python3, the code is from 2012.
Have you tried running 2to3 on it? I have not tried this particular program but 2to3 can be quite helpful in bashing python2 code into something that might run in python3.
