Using Kicad v7.0.2
I have some PTH holes in my design. Design rule set to min anular ring 0.35mm.
Pad size 5.5mm
Hole size 3.2mm
DRC check complains: “min annular ring 0.35mm, actual 0.2mm”
I would expect annular ring: (5.5 - 3.2) / 2 = 1.15mm
Even with some tolerances it is much more than 0.2 mm
Is my understanding correct ?
Correct IMHO. I did a quick check as well and DRC was not complaining here. So something else must be going on. Hard to say without having the board…
Thanks for your reply. At least I know id didn’t overlook something obvious. I will try to find out why it’s happening. Will first try with the same footprint in a ‘fresh’ PCB design to see if it behaves the same.
eelik
May 5, 2023, 7:37am
4
Check that you don’t have any extra overlapping items, hidden by other items.
system
Closed
August 3, 2023, 7:38am
5
