Hi ,
Can anyone explain why missing track 3.3v to pin header in here is not detected through DRC ?
Pls note that I didn’t change DRC settings and settings are default.
It should be. The ratsnest line indicates that the connection has not been made. Did you check under the Unconnected Items tab in the DRC window? Post a screenshot of that.
I suppose it would help if you could attach a project (File-Archive Project in main KiCad window).
For how to get permission for it read:
Thanks for the tip .I will attach the project
It shows under the "Unconnected Items " tab. Thanks you for pointing that out.
Thanks for the help.
Yes, it’s a separate tab these days.
Unchecking the"errors" tick box also would hide this
