I’d like to set a warning and an error for hole_to_hole spacing such that when I move a via, it highlight a nearby via a color representing warning (yellow) if the penetration clearances will merge (creating a slot) and a separate color representing error (green, as is the present default) if the vias are closer than manufacturing allows.
Is there a means to perform this?
I do not believe that warnings presently display a different color in the interactive router.
I believe the DRC custom rules will never check for the warning, since the condition will first be met by the error, given the DRC custom rules code below:
(version 1)
(rule "Distance between Vias (Hole to Hole) (Don't Break Return-Plane Path)"
(severity warning)
(constraint hole_to_hole (min "0.254mm + 0.254mm + 0.09mm"))
(condition "A.Type =='Via' && B.Type =='Via'")
(rule "Distance between Vias (Hole to Hole) (Different Net)"
(constraint hole_to_hole (min 0.5mm))
(condition "A.Type =='Via' && B.Type =='Via' && A.Net != B.Net")
(rule "Distance between Vias (Hole to Hole) (Same Net)"
(constraint hole_to_hole (min 0.254mm))
(condition "A.Type =='Via' && B.Type =='Via' && A.Net == B.Net")
Update
Posted feature request here.
