Drawing Sheet Image Size Mismatch
Doing the interconnect for my project and wanted to make a title block that better matches my 100 or so mechanical drawings for the project. Got it where I wanted it, saved, went to the interconnect and imported it…and the logo increased in size massively and the license graphic shrunk in comparison to the drawing sheet.
How can I easily fix these two images in the drawing sheet so it stays consistent when I add it to the schematic?
Drawing Sheet Editor:
Schematic Editor:
Version Info
Application: KiCad Drawing Sheet Editor x64 on x64
Version: 7.0.1, release build
	wxWidgets 3.2.2
	FreeType 2.12.1
	HarfBuzz 5.0.1
	FontConfig 2.14.1
	wxWidgets: 3.2.2 (wchar_t,wx containers)
	Boost: 1.80.0
	OCC: 7.6.2
	Curl: 7.83.1-DEV
	ngspice: 39
	Compiler: Visual C++ 1934 without C++ ABI
	KICAD_SPICE=ON
I’ve been banging my head off the wall to figure this out for a couple hours before posting…but as usual, figured it out right after posting.
  1. Saved the drawing format
  2. Closed and reopened the drawing sheet editor.
  3. Adjusted DPI to size the images appropriately.
  4. Closed and reopened the schematic.
(Wrong metadata here, but that’s okay.)
