I am new to Kicad and I am stuck trying to create a personalised title block. I can see a lot of documentation and videos for Page Layout Editor but nothing for Drawing Sheet Editor. I do not think they are the same thing.
Kicad 7 documentation also seems to be for page layout editor. Is there an introductory article for the Drawing Sheet Editor?
introducing the document as being for Page layout Editor.
It is also different from what I see. For example my variables are referenced with $ symbol instead of %. My window is different from what is in the document.
Well that’s what it is named as at the top level docs.kicad.org. That document is a few years old as it might be out of date. But I don’t use it so someone else will have to comment.
I think there has been an informal renaming of the components of the suite:
Thanks, that makes sense. I’m just not sure since my window is similar but not the same as what is in the documentation. I also cannot make any edits which is very strange.
I think it’s like with the other editors, you can’t edit the system libraries but have to create your sheets in your own directories. There should be a ready made directory in your personal config.
