I’m trying to draw a footprint for TC2050-IDC (a Tag-Connect that has four bigger non-plated holes for the plastic legs to latch, and three small non-plated holes for three alignment pins). The ten contact pads can be treated as SMD pads which is straightforward. The problem are the outer 4+3=7 non-plated holes. The spacing between the non-plated holes and the closest SMD contact pads can be 0.015in or less so I really have to keep these outer holes non-plated (no copper around the holes!). There are no allowance for adding small TH copper pads around the holes.
In the footprint editor, I set pad type to “NPTH, Mechanical” and the pad diameter to be 0in. I got the error that says “Pad must have a positive size”.
Can I set both the pad and the hole to the same diameter or will I run into issues later on? And should I set the Copper Layers to “None”
Or is there a better way to that in Footprint in KiCAD v8?
I like to do the hole thing in one footprint and avoid doing a separate drill files in the PCB and align the two separately.
KiCad version 8.0.2
