Dot grids are not centered
Hello everyone,
I am making a PCB. Part of the work is center some objects on specific place.
I set gird to 1mm to make easy count how many mm i need move the piece.
Here i found a problem, the gird dots are not centered to 1mm. The dots has 1mm of distance and the cross go from dot to next dot, but they are not on rounded number. So the cross is allways displaced 0.18mm tothe round number
imagen
Thanks in advance
Most probably your grid origin was not set in mm, you can use the set grid origin to eliminate the offset.
Thanks for your answer. i set the origin in mm. The partial solution was close the PCB editor and open again
Your origin is off-grid as seen in your first picture (the circle with the cross).
Thanks and sorry, i didnt find this button. The toolbar is configurable to add it? Any other place to find this?
Yes. If you look you will find this function duplicated in “Place”. You can also keep footprints aligned to the grid in “Preferences”.
Thanks you for the help
I don’t think so, but icons with small arrow in their bottom right corner contain more actions (click longer at them to see).
Looking at your first screenshot and if your window it is maximized, it may seem that the resolution of your screen is not enough to show all icons in the UI, this is what I see on my screen:
Is possible. Is a standard notebook of 15 inch with 3 years old. But the resolution thing was an old discussion and refused. If i am poor is my problem, i didnt will say anything more about this point.
I use the menu. Thanks
