Dogbone limitations
I tried to use a newly introduced feature called Dogbone to cut arc hole outlines with a 1-mm drill bit as described in Draw an arc hole? - #13 by dizcza.
Unfortunately, the Dogbone feature does not work on arcs: it seems to work only on line segments though this isn’t mentioned in the feature description.
I’m posting this as a feature request.
Moved to the issue tracker: Feature request: Dogbone should support arcs (#21179) · Issues · KiCad / KiCad Source Code / kicad · GitLab
Hi @dizcza
Feature requests need to be made in Github.
Open Kicad > Help > Report a Bug.
Instead of reporting a bug use “Feature Request” in the title.
On the LHS in the index you will see a title “Issues”. Click on that to see how others report bugs and make requests.
All right. I moved it to the issue tracker and marked this conversation to be deleted.
I seem to have undeleted it… :smile: In any case, it doesn’t hurt to discuss possible wishes or usability here first as long as you know we are just end users who give their opinions and can offer our particular expertise here.
It’s good to add link to the actual gitlab feature request here.
It is best to leave this thread available for future reference by anyone interested in the problem.
Also, if you make the request, please post a link in this thread for others to read.
