Hi. Built KiCad from source. Everything work fine, but in doesn’t switch interface language.
When i pick another language it blink, but everything stays in English.
If I try to change the language to anything else but English, KiCad starts yelling at me:
It might be that you have to install translation files separately before you can use them.
No errors. Just blink interface and everything in English.
If you are building from source, you’ll also need to build the translations from source (https://github.com/KiCad/kicad-i18n). Just do the standard cmake in a build directory and then make install.
That works! Thank you!!
