Hi all, and thanks in advance for your help.
I will start with a bit of background. I work for a circuit board test company, and occasionally we produce one off circuit boards to aid in our testing.
My task is to reproduce a PCB designed by another company. (I intend to use kicad_skip to automate a great deal of this task, as most of the locations of the components and testpads are known in advance)
The PCb I am duplicating has multple layers (I think 10) 2 of which are ground planes.
The top layer is very dense, I will not be able to add any further circuitry to it.
The bottom layer consists of a grid of header pins. (see attached image). the header pins are the subject of this post.
The header pin socket is a blind hole through the bottom 5 layers, with a donut solderpad on the bottom most layer. (am told the hole itself is not plated, as this may cause the hole to be too small for the pin to be inserted.
This is the feature I am trying to reproduce in kicad.
I have a co-worker who is also attempting to duplicate this feature using Altium and he says that the only method he can think of is to add a blind via, then ask the FAB house not to plate it.
But I would like to avoid none standard parts if possible.
Does anyone know if describing this in keycad is possible?
If I have explained anything poorly, feel free to ask for clarification.
Thanks again in advance.
Andy
