kicad-cli seems very useful for my purposes. Where can I find a documentation of the commands and options of kicad-cli. Unfortunately --help is not helpful.
as far as I am aware there is no other documentation right now then -h
and the short section in the development highlights/7.0 previeww: Development Highlight: December Edition, features coming to KiCad 7 | KiCad EDA
I have since found out that the help from kicad-cli is more comprehensive. However, --help is not used as usual, but will be put after the subcommand or option. I will go in search of examples.
Some good examples can be found at TechOverflow at Du hast nach kicad-cli gesucht - TechOverflow.
Some more examples:
Export all pcb layers into individual files at once
kicad-cli pcb export svg --output "kiri/pcb/layer-00.svg" --layers "F.Cu,Edge.Cuts" board.kicad_pcb
pcb export pdf accept different layer names than displayed in gui
kicad gui -> kicad-cli
User.Drawings -> Dwgs.User
User.Comments -> Cmts.User
User.Eco1 -> Eco1.User
User.Eco2 -> Eco2.User
Also you can put there * and the it will export all layers (didn’t check whether it is actually all):
kicad-cli pcb export pdf -o fig/pcb_drawing.pdf ./light_ring_3535x6.kicad_pcb -l "*
If someone uses kicad-cli, his commands could be used here as examples for documentation.
Edit, indeed, you found that, and it works recursively into further sub commands.
paul@cezanne:~/projects/kicad/mumar_rack$ kicad-cli -h
Usage: kicad-cli [-h] {fp,pcb,sch,sym,version}
Optional arguments:
-v, --version prints version information and exits
-h, --help shows help message and exits
Subcommands:
fp
pcb
sch
sym
version
paul@cezanne:~/projects/kicad/mumar_rack$ kicad-cli pcb -h
Usage: pcb [-h] {export}
Optional arguments:
Subcommands:
export
paul@cezanne:~/projects/kicad/mumar_rack$ kicad-cli pcb export -h
Usage: export [-h] {drill,dxf,gerber,gerbers,pdf,pos,step,svg}
Optional arguments:
Subcommands:
drill
dxf
gerber
gerbers
pdf
pos Generate Position File
step
svg
paul@cezanne:~/projects/kicad/mumar_rack$ kicad-cli pcb export svg -h
input: 1 argument(s) expected. 0 provided.
Usage: svg [-h] [--output VAR] [--layers VAR] [--mirror] [--theme VAR] [--negative] [--black-and-white] [--page-size-mode VAR] [--exclude-drawing-sheet] input
Positional arguments:
input Input file
Optional arguments:
-o, --output Output file name [default: ""]
-l, --layers Comma separated list of untranslated layer names to include such as F.Cu,B.Cu [default: ""]
-m, --mirror Mirror the board (useful for trying to show bottom layers)
-t, --theme Color theme to use (will default to pcbnew settings) [default: ""]
-n, --negative
--black-and-white Black and white only
--page-size-mode Set page sizing mode (0 = page with frame and title block, 1 = current page size, 2 = board area only) [default: 0]
--exclude-drawing-sheet No drawing sheet
