I have been asked if it is possible not to have the red cross when ""Do Not Populate is selected in V7. The grey colour symbol is OK
No, not possible. If you don’t want the cross, the only solution is to not use that feature and instead indicate DNP with field or something.
First of all, I am happy to see the option “Do not populate”. I had asked for such an option in the past. Its very handy, especially once you want to have alternative options for connections on a board, using 0 Ohm resistors. Some can be pre-populated, others not.
But I do agree with davidsrsb. This big red cross over the grayed out component looks terrible. Grayed out only without the red cross would be perfectly fine.
I also agree 100% with you.
But the original discussion is already some days old and in the meantime a configurable color for this red cross was introduced into the developer version.
So with v799-nightly you already can change the red-cross opacity to zero, so no cross is visible.
Stuck until the end of the year then.
Fantastic!
Will grap the v799-nightly. Thanks!
I think it may well have been copied from Altium . . .
I don’t mind it as I see it quite often, I’ve become used to it.
