I would like to make just one observation regarding “Do not populate” and it concerns the color made transparent. So it’s hard to see anyway, example on a pdf, it would be better to be able to choose the color you want, for this function. A gray color for example, is easier to see, in my opinion…however I didn’t find this function,maybe there is…
Adding the “Do not Populate” flag makes the symbol pretty “bleak” and on the .pdf it looks the same, except when you create a .pdf in Black & White, then you do not see any difference.
I do not like the significance of colors for a thing like this. My preference would be to have a text string like “DNP” or some other graphical mark for it on the schematic.
I have been putting DNP in the value field of parts, or sometimes with a hint, like DNI-470pF.
Now with the database all parts will be atomic so adding a DNP text next to the part for printing (as well as the flag to keep it off the bom) will work. I also print schematics in B&W but I do like to soft glow of dnp parts on the screen.
Actually, even with parts pulled from the database, the standard parts lib is still available, so I suppose I could still plop a non-atomic cap and set the Value to DNP (as well as the flag). Need to play with this when I start my first v7 project.
Checked with most recent Windows version kicad-nightly-r31004.
Light color may be o.k. for color print, but we definitely need a visualization of DNP attribute in bw print. I like crossed-out symbol in Altium or Expedition. I guess the cross is on the bounding box diagonals, don’t know if it’s easily available in KiCad schematic graphic.
Yes, adding some text might be an idea, but it still forces you to check all the text in the pages, when with a completely different color or a cross (Altium style), it’s easy to see.
I guess changing the color to transparency is easier from a programming point of view, I understand that, but if we want to simulate a variant of the schematic, then it would be better to delve into it via software…
Have you already filed an issue for this? I can upvote it.
Issue Done…
Why don’t you give a link to the issue? It may gain more votes that way…
Already fixed! ------
