I have a pcb that contains mostly through hole parts… but I do have 3 smd parts on the back of the pcb.
I am making 250 of these so I want to have a solder paste stencil made.
So the question is do I have to create a separate stencil layer?? can OSH Stencils create the stencil from the copper layer that contains the SMD devices??
If I need to create a separate Stencil layer then is that the only file layer that I need to send them?
Also if I need to create a separate stencil layer is it any different from just making regular footprint pads for smd devices??
Attached is a snapshot of the PCBNEW screen with all the layers turned off. All I want is a stencil of the green SMD pads.
HELP me OBIWAN!!!
thanks
dwight
