The board classes calculator shows a table of values for class 1 through class 6 boards. The first column identifies the type of value displayed in each row. Unfortunately, the column is not wide enough. All I can see is “(diam - drill)”. The first over-wide entry shows a portion of a letter A, so I suspect that deals with vias, but the other two?
For me it’s all perfectly visible (Linux Mint).
The yellow thing is “Screen Ruler 0.9.6” from Ian McIntosh and it just measures pixels at the moment.
I’m using MS Windows 10 Pro N1H1 on a Toshiba Tecra
