Disappeared icons
kicad 9.3 disappeared text icons and draw text boxes
There is no KiCad V9.3.
sorry I meant latest version 9.0.3
From what I understand and from my research, Kicad does not allow you to add or remove icons from the toolbar.
Well then, edit your post to fix it, and then we can delete a few posts that are mostly noise.
I have not used V9 yet, but I do indeed not expect menu’s to be modifiable. Part of the cause (I think) is because KiCad uses wxWidgets, and that framework is improving, but slowly. Another reason is that there is a long list of feature requests, and modifying some buttons is probably not high on the todo list.
But if you’re having problems with the default configuration, posting a screenshot may help. You’re also very sparse with information. Did they “suddenly” disappear, or did they never work for you in KiCad V9? How did you install it? Maybe you used a damaged download. Without more information from your side, it’s just guesswork.
I still have them in 9.0.3 in both schematic and pcb editors, assuming these are the ones you mean.
Yes, exactly those. Basically, if I add small icons, they’re there, but with medium-sized icons, they disappear.
I should point out that I use Orcad at my company and have two monitors. I wanted to know if it’s possible to move the toolbars to a second monitor display.
Thanks
Apart from changing icon size in Preferences, you can also reduce display scaling factor in your OS’s settings.
