working on Windows 10 64 bits (or Win8.1 64 bits on another test platform, but results are the same)
I can set KICAD_PTEMPLATES in system environment variables or eventually on KiCad “preferences/Configure Paths…” menu.
if I want to create a new project from template, I get a window with 3 tabs : “system templates”, “user templates” & “portable templates”.
actually on my test system, only “portable templates” point to the directory corresponding to KICAD_PTEMPLATES.
is there a way to set the directories value for the two other tabs ??
“system templates” point to KiCad install dir (C:\Programs\KiCad\share\kicad\template) and “User template” point to a directory in my user documents dir (C:\Users\FLT\Documents\kicad\template).
sorry for replying to myself only a few minutes after asking, but it tried different things again and found a solution to my problem and since I’m not able to delete the post, here is my answer…
I didn’t find where I could set the other directories, but I understand why I couldn’t select another directory with the browse button, so no more need to set the directory before.
I was selecting the final directory (for example “Arduino_mini”) and get several file errors.
if I only select the “template” directory (containing several sub-directories, like “arduino_mini” and other templates), it’s working. I can see the different templates present and select one.
Fred
