Directory Organization
Perhaps the answer to that lies in FreeCAD when we install KICAD new?
All I know is this library thing makes my brain hurt. I think I am getting my head wrapped around it but it would seem like there would be a very easy and intuitive way of doing this.
A post was split to a new topic: Connect to part outside schematic
I’m leery of those third party libraries. Sometimes they require work to correct infelicities before use. Even when all the symbol pins are numbered correctly and in a good orientation they often have the wrong or indifferent electrical types for ERC. Sometimes it’s faster to DIY symbol. As for footprints most parts are covered by the standard collection. Occasionally I use the wizard to make a footprint, e.g. for some nixies. I’ve put together a 3D model using Freecad for a LED digit but often I do without a full 3D rendering since the project is for myself.
I think you’re overthinking this. There’s no need to build a comprehensive personal library, just accumulate entries as you go, either by adapting the standard entries, DIY, or from other sources.
BTW I’ve split off your question about off schematic parts. A new topic is needed so that your question won’t get lost and also be off topic for this thread.
Agree, except sometimes lots of work.
Which brings up another point:
It may well be quicker to ā€œfigure outā€ using the Kicad Symbol and Footprint Editors for you, after which, you won’t have to bother searching for 3rd party stuff. :slightly_smiling_face:
I use GitHub for my projects, and I copy the entire folder every time I send a ā€œversionā€ for manufacture. So if I find the PCB later on I know where is the project.
Inside the project folder, I have a mess because I do not understand what the files are, but I try if possible to put all files in there and not use the library, since a new version of Kicad can esily break them:
There is a fantastic project that automatically generates images, schematics files, and production files every time I commit to Git: GitHub - INTI-CMNB/KiBot: KiCad automation utility
I still have a lot of room for improvement, but I feel it’s the right direction (for my use case)
