DipTrace/Eagle import: Values missing
Hi all, I am trying to import Dave Erickson’s DIY-SMU Dave Erickson DIY SMU Source Measure Unit Project into KiCad. Dave exported the files from DipTrace in Eagle format:
DIY-SMU Eagle.zip (88.6 KB)
which I then imported into KiCad. It does look quite decent, but the most annoying problem is that the component values are missing:
Although there seems to be a value attribute in the Eagle XML file
<part name="R32" library="common" deviceset="RES_0805" device="" value="100K"/>
the 100K value is imported as text (in blue below the resistor symbol).
Does anyone have an idea how to fix this?
