(module Diode_TH_SOD123 (layer F.Cu) (tedit 59A2D265)
(descr "Diode, DO-41, SOD81, Horizontal, RM 10mm,")
(tags "Diode, DO-41, SOD81, Horizontal, RM 10mm, 1N4007, SB140,")
(fp_text reference DIODE (at 5.38734 2.53746) (layer F.SilkS)
(effects (font (size 1 1) (thickness 0.15)))
(fp_text value D (at 4.37134 -3.55854) (layer F.Fab)
(fp_text user DIODE (at 5.35 2.54) (layer B.SilkS)
(effects (font (size 1 1) (thickness 0.15)) (justify mirror))
(fp_line (start 4.5 -0.7) (end 4.5 0.7) (layer F.SilkS) (width 0.15))
(fp_line (start 4.5 0) (end 5.4 -0.7) (layer F.SilkS) (width 0.15))
(fp_line (start 5.4 0.7) (end 4.5 0) (layer F.SilkS) (width 0.15))
(fp_line (start 5.4 -0.7) (end 5.4 0.7) (layer F.SilkS) (width 0.15))
(fp_line (start 4.5 -0.7) (end 4.5 0.7) (layer B.SilkS) (width 0.15))
(fp_line (start 5.4 0.7) (end 4.5 0) (layer B.SilkS) (width 0.15))
(fp_line (start 5.4 -0.7) (end 5.4 0.7) (layer B.SilkS) (width 0.15))
(fp_line (start 4.5 0) (end 5.4 -0.7) (layer B.SilkS) (width 0.15))
This file has been truncated. show original
does it support both SMD and through hole diodes?
I haven’t checked any dimensions, but you don’t need SMT pads on both sides of the board. When laying out a board you can choose which side the SMT pads go (which will free up board real estate on the opposite side for routing traces or placing other SMT devices).
system
Closed
April 19, 2018, 1:59pm
3
