Differential pair track width seems not to be respected
I am struggling routing a differential pair (DP). What I would like is a certain track width for single-line routing (to move away from the footprint where the tracks start) and then the impedance adjusted settings for when the tracks are routed as DP.
My set-up in the netclass dialog is as follows:
When there are absolutely no tracks connected to the net, then this works:
However, when I have tracks with another width at either end, then the differential pair is routed with this width instead of the one set in the netclass setup.
What am I doing wrongly here?
Does toggling the selection of this button change the behaviour?
Yes, it does, thanks for pointing this out !
But then the next problem occurs: The width of the track stubs I connect to are changed when I finish the track:
Here is what I see while routing:
When completing the track, everything connected is changed to the DP width:
It seems I can work around this by locking the track stubs, but I think it would be good to have a way not to change the width of existing tracks when connecting to them.
Should this be set up in the design rules from the start based on the project requirements?
