I am currently routing a PCB that has multiple differential pairs. Each has to have 0.15mm pair gap, which I have implemented in a custom rule (will change depending on layer in final version).
The issue I am having is that once I correct for the differential pair skew, when I run DRC it now shows hundreds of gap issues due to the added length matching skew.
Is there a way to turn this off the gap check rule for segments that have length tuning added to them?
