in the Version: (2017-02-08 revision 0dc1193)-makepkg, release build nightly I stumbled over a design rule / differential pair dimensions issue. Perhaps its my bad, so I do not want to bother the bug list in the first place.
Issue: whenever I touch the design rules, even just checking without any changes made, I get an error (see below).
Will do in the next days. Thanks. I will use r7663, the later nightlies are painstakingly slow whenever any connectivity is touched (like adding a wire or generating a netlist) and occasionally crash in Pcbnew. But then, these are nightlies…
I am convinced this is a bug. The only thing we can do now is to find a workaround for you.
(And in this process also find out more about the bug such that a better bug report can be made.)
No need to put any effort in there for me. Firstly the project is for personal/hobbyist use only and secondly I am fine with 4.0.5 stable. Was just testing.
But thanks for your offer anyways.
And there is no entry for the differential pair parameters in the xxxx-kicad_pcb. Which makes it clear why Pcbnew always starts with the same weird settings.
