I found only old posts and not clue if they’re still valid.
However my question is the following (included the situation description):
By making microphones, I often need to design several circuits.
Each PCB is different form the other. Each PCB is belonging to a specific schematic.
Generally speaking, the PCB number is from 2 to 5 (depending from the model)
For the time being, I’m sending files form each project to the manufacturer. It means from 2 to 5 uploads each time, by entering always the data for each upload. Yes sometimes it’s occurred that I’ve made some mistake by choosing some parameter (like the thickness or the color or something else) and I had to reorder the whole stuff.
Here my question: I would like to send to the manufacturer only a panel with all the PCBs inside it.
So I can make only one upload and I’m sure the parameters I set up, are identical for che whole project. So I can diminish the probability to make mistakes due the repetitivity of actions.
Is that possible within KiCAD so far?
If yes, how?
Thank you in advance
