I’ve got both a mouse and a Wacom stylus (Intous2) for my pointing devices. I notice that there is a difference in behavior in button clicks between the two devices, but only when it comes to the opengl canvas (not the default). First off, the first time I’ve tried the opengl canvas was today. But the 3-button mouse act normal, like I’d expect (i.e. behaves the same as in “default”), but when using the stylus, I need to double click to begin a track, and once a track is in progress, I can’t right click to bring up the context menu, but I can still middle click to pan. Is there a setting which might govern this that I am overlooking? Is this more likely to be a pcbnew issue treating the mouse and stylus differently, or maybe something with the opengl driver on my machine, or possible interaction between the OS and opengl and mouse drivers? Anyone else come across something like this before?
Thanks,
Greg
Application: kicad
Version: 4.0.7 release build
wxWidgets: Version 3.0.3 (debug,wchar_t,compiler with C++ ABI 1011,GCC 7.1.0,wx containers,compatible with 2.8)
Boost version: 1.60.0
Curl version: libcurl/7.54.1 OpenSSL/1.0.2l zlib/1.2.11 libssh2/1.8.0 nghttp2/1.23.1 librtmp/2.3
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_WXPYTHON=ON
USE_FP_LIB_TABLE=HARD_CODED_ON
BUILD_GITHUB_PLUGIN=ON
