I’m using the latest KiCad build (see version info below) and I’ve noticed that per sheet annotation got broken in my setup.
I try to annotate a schematic sheet with the following settings:
But instead of getting symbol references with appropriate sheet number as the first digit (e.g. “R301”) I aways get references with “1” as the sheet number (e.g. “R101”). It used to work OK several weeks ago.
This is a hierarchical design with a root sheet and four “branch” sheets. All sheets are different (e.g. no reusable blocks)
Could someone please check it on their latest build and report?
Application: eeschema
Version: 0.201601171446+6489~42~ubuntu15.10.1-product release build
wxWidgets: Version 3.0.2 (debug,wchar_t,compiler with C++ ABI 1009,GCC 5.2.1,wx containers,compatible with 2.8)
Platform: Linux 4.2.0-24-generic x86_64, 64 bit, Little endian, wxGTK
Boost version: 1.58.0
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_WXPYTHON=ON
USE_FP_LIB_TABLE=HARD_CODED_ON
BUILD_GITHUB_PLUGIN=ON
