Hi folks, I have a question.
When using an external plug-in in PCBNEW, a save changes dialog appears when you close PCBNEW, even if the plug-in did not modify the board.
Why? Is there any way around it?
Thank you for answer.
At the moment pcbnew does not have a way to tell if the plugin modified the board or not so it just assumes that it did. There is no way around it (without patching kicad itself).
OK, thanks for the info.
