Itâs a color well, so Iâd expect it to allow me to change the color. I do think a radio button (or something similar, where I fundamentally see something I know I can click on rather than just empty space; if the entire list was inside a wxListCtrl or similar, and selecting the row was more visually obvious, that would work too) would be more clear than the blue arrow for indicating active layer, though. I also wouldnât mind if the color well and/or the visibility checkbox were in columns to the right of the layer names instead of (as shown) to the left (especially if there is no radio button, and clicking the layer row remains the only selection method).
Changing color wouldnât be something Iâll be doing often even if I want to, so I am not sure why there is a need to have it available on the right of the screen. If anything itâll be annoying if a click on the color square and a pop up appears for colour change when I want to change the layers, which I WILL be doing often.
Eh⌠I think Iâll need to try to see how it works. But I am perfectly fine with the current system of select active layer and I donât see a need to change colors at all. Maybe others will feel differently.
Just an idea: what if we change the layer visibility selector to be an eye (similar to the gimp layer visibility.)
Might make it more clear for beginners.
It should be easy to know what color is what layer. So the colored rectangle should stay. (or something similar.)
Reading screenshots would get nearly impossible without this information. (Would make life on this forum a bit harder.)
To be honest i click on the layer name to change the active layer. This way i donât run into the problem of clicking on the color selector.
Once you have a color square, you have the suggestion that itâs clickable and you can do things with it. My suspicion is that itâll still look âclickableâ to most users no matter how it is formatted, because almost all color wells in GUIs are clickable, so since you have a color square youâre stuck making it do something sensible
Personally I think I click on the layer name to select the active one, so if the color swatch/button now leads directly to selecting the color I shouldnât be affected.
Oh and in case youâre open to suggestions - double clicking on a layer label should toggle visibility (too). I can double click faster on a large target than single clicking on that little check mark.
Itâs not so much a workflow, just that when you have a crapton of layers it really helps for them to have easily distinguished colors, and the color set that works for one person might not necessarily be what works for another. So I like to set up my layer colors to something that works well for me. I find it particularly important for 6+ layer boards.
Clicking anywhere on the layerâs line (left from color well, on color well and on layer name) switches this layer to be active, but clicking on the checkbox (obviously) changes the visibility.
To be consistent, Iâd expect a left click on the color well to pop up the color chooser dialog or have a different way to toggle the visibility, i.e. no single-left-click, which would be counter-intuitive as well âŚ
+1 from me for that idea. Maybe it would also suffice if the columns had a heading like in @dbrown2kâs post (eye or lightbulb for the visibility, color pattern for color selection, etc.), then the check boxes might remain the way they are (my guess is that itâs less modification to the code).
Seems like a good idea to me.
On the Linux variants, hitting the right target is much easier as it is in windows because the UI elements have much more spacing around them. Iâve made a few screenshots to illustrate this:
I think the right-click property menu is a good place to access the color chooser.
I realise that if the color chooser came up accidentally because I was trying to select a layer, that would be quite annoying, but it seems I canât change my vote!
But itâs something you only do once, maybe a few times until you settle on a color scheme but then youâre likely to never touch it gain. I would be happy having to go through a menu from the menu bar in order to change layer colors, and quite annoyed if I kept getting a color picker popping up by accident.
Whyâs everyone fixating on clicking them accidentally? It was suggested to move the color squares over to the right so they donât get in the way, would that suffice?
The reason I say this is:
The color squares are going to have some color-related behavior, because theyâre there and they have colors on them. We canât really get rid of them, since you need some cue as to which layer matches which color. If theyâre taking accidental clicks, Iâd much rather solve that problem directly by moving them so they donât get clicked unintentionally.
In the past/present left-clicking on them selects that layer. You want to change that behavior that is where the âaccidentalâ clicking will come in. You can already middle-click them and change the color. And I donât think it will be very aesthetic moving them to the right.
