Design of the main power module PCB for the Terraohm measuring equipment Task: Study the results of the development of the Terraohm measuring
Title: Design of the main power module PCB for the Terraohm measuring equipment Task: Study the results of the development of the Terraohm measuring instrument with particular regard to the instrument’s energy requirements. Finalize the instrument’s energy needs with the units completed so far in the development and the switching mode power supply board model that supplies them. Based on the energy requirement, in response, network transformer and design the rectifier block on the secondary side of the transformer. Create the combined circuit diagram of the power supply block, the rectifier and the previously completed switching power supply model using the Kicad design software. Choose parts that are available at dealers. Check the standard parts footprint and 3D models. For special parts, make them. Design the printed circuit board and its production documentation in the volume specified in the preliminary construction plan. When planning, make sure to observe the standard insulation distances and creepage current paths, observe the rules of life protection class I. The printed circuit board will be on a two-layer panel.
I need help
This is not a do my homework forum.
https://www.eevblog.com/
This forum is about using the Kicad software, nothing more.
Interesting you thought this was a 3D model problem. :wink:
