Testing out 5.0.2, I think some behavior has changed in EESchema. When I select items on the schematic using a box selection, I can’t delete those items using the delete key. I have to either use CTRL-X or right mouse click and select cut. Is this a change in behavior, and is there a chance we’ll get the old behavior back? Can someone verify that Linux behaves the same way please?
EDIT: I should have added that I’m running on 64-bit Windows 10.
Thanks
