I want to delete all footprints which have a certain value in a field in the schematic so that I can generate a custom paste layer Gerber which contains only certain footprints. I started writing a Python script but there seems to be no way (KiCad Pcbnew Python Scripting: pcbnew Namespace Reference) to access the schematic field values from within PCBNew. Is that so or any other idea?
Ok, I managed somehow to find something in the depths of the Doxygen documentation. For who is curios:
#!/usr/bin/python3
import pcbnew
import wx
class DeleteComponentsPlugin(pcbnew.ActionPlugin):
def defaults(self):
self.name = "Delete Components Without EC=YES"
self.category = "Modify PCB"
self.description = "Deletes all components that don't have 'YES' in the 'EC' field"
def Run(self):
# Get the current board
board = pcbnew.GetBoard()
# Get all modules (footprints) on the board
modules = board.GetFootprints()
# List to store modules to be removed
to_remove = []
# Iterate through all modules
for module in modules:
ec_value = ""
# Get the reference item (which contains the fields)
reference = module #.Reference()
# Iterate through all fields
for i in reference.GetFields(): ##range(reference.GetFieldCount()):
field = i #reference.GetField(i)
if field.GetName() == "EC":
ec_value = field.GetText()
break
# If EC is not "YES", add to removal list
if ec_value != "YES":
to_remove.append(module)
# If no modules to remove, show message and return
if not to_remove:
wx.MessageBox("No components found to remove.", "Info", wx.OK | wx.ICON_INFORMATION)
return
# Ask for confirmation before deleting
dlg = wx.MessageDialog(None,
f"This will delete {len(to_remove)} component(s). Are you sure?",
"Confirm Deletion",
wx.YES_NO | wx.ICON_QUESTION)
result = dlg.ShowModal()
dlg.Destroy()
if result == wx.ID_YES:
# Remove the modules
for module in to_remove:
board.Remove(module)
# Refresh the board
pcbnew.Refresh()
wx.MessageBox(f"Deleted {len(to_remove)} component(s).", "Success", wx.OK | wx.ICON_INFORMATION)
else:
wx.MessageBox("Operation cancelled.", "Cancelled", wx.OK | wx.ICON_INFORMATION)
DeleteComponentsPlugin().register()
