Not sure about the category, because my question is more about the file format and the handling of EESCHEMA.
I am working on a Library Generation Script. I would like to know if there is an option to have a different Symbol Value from it’s Symbol Name. There is Field 1 in the file format, but it is not used in EESCHEMA, I guess it only gets used as soon as the symbol is placed in a schematic. But in the library, the “Value” field is always filled with the Name.
My dodgy solution would be to turn the Value field invisible and add a Custom field on the same spot which contains the actual “Value”.
Any thoughts on that?
