Debian - KiCad 5.0.0-rc2-dev - EESchema sluggish
Since KiCad 4.0.7 is broken in Debian Sid, I just installed KiCad 5.0.0 from Debian experimental.
Eeschema is running very sluggish in this configuration.
Any idea what can cause this ?
Below the Kicad version info
Application: kicad
Version: 5.0.0-rc2-dev-unknown+dfsg1+20180318-3, release build
wxWidgets 3.0.4
libcurl/7.58.0 OpenSSL/1.0.2o zlib/1.2.8 libidn2/2.0.4 libpsl/0.20.1 (+libidn2/2.0.4) libssh2/1.8.0 nghttp2/1.31.1 librtmp/2.3
Platform: Linux 4.16.3-towo.1-siduction-amd64 x86_64, 64 bit, Little endian, wxGTK
wxWidgets: 3.0.4 (wchar_t,wx containers,compatible with 2.8) GTK+ 3.22
Boost: 1.62.0
Curl: 7.58.0
Compiler: GCC 7.3.0 with C++ ABI 1011
USE_WX_GRAPHICS_CONTEXT=ON
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_SPICE=OFF
My system information
System: Host: bruno-pc Kernel: 4.16.3-towo.1-siduction-amd64 x86_64 bits: 64 Desktop: KDE Plasma 5.12.4
Distro: siduction 17.1.0 Patience - kde - (201703051755)
Machine: Device: laptop System: LENOVO product: 4391P2G v: ThinkPad W510 serial: R9AE298
CPU: Dual core Intel Core i7 M 620 (-MT-MCP-) cache: 4096 KB
clock speeds: max: 2667 MHz 1: 1427 MHz 2: 1332 MHz 3: 1316 MHz 4: 1280 MHz
Graphics: Card: NVIDIA GT216GLM [Quadro FX 880M]
Display Server: x11 (X.Org 1.19.6 ) drivers: nouveau (unloaded: modesetting,fbdev,vesa)
Resolution: 1920x1080@60.00hz
OpenGL: renderer: NVA5 version: 3.3 Mesa 17.3.9
I corrected your version info in the title to avoid confusion. You are running a development (nightly) version not a release. (V5 has not yet been released)
thanks, indeed should have been more precise there
Some additional info : the interface reacts better when zooming in very much on the components
This option should be disabled unless running on Mac. It will slow down Eeschema substantially.
Hi Seth,
Is this a build problem ? If yes, I will take it up with the Debian package maintainer.
Brutor
Yes, definitely a build issue.
The problem here is wxWidgets build using GTK3, it causes a lot of troubles in KiCad. USE_WX_GRAPHICS_CONTEXT=ON is by default added for wxGTK3 builds to mitigate some of the problems, but it reduces the performance.
