I’m getting DRC for a net bridge and a capacitor and there’s a rat nest line showing a connection between.
I’ve redrawn the tracks many times and the errors won’t go away.
To me it looks quite clear, although I can’t see the rest of the board. All GND pads must be connected to all other GND pads directly. If there are separate areas, they must be different nets. You have now two completely separated GND areas in the upper screenshot. You should connect them to the rest of the GND net. The net ties are no-connections from the viewpoint of the DRC.
OK another via needed - thanks
