Does anyone know any information about DDR3 layout requirements ?
If I have 32 bits CPU, and using 2 x 16bits DDR3,
the configuration will be lower data bits 0-15 to the first DDR3 chip,
and upper data bits 16-31 to the second DDR3 chip ?
Thanks for that,
Ok, I will route it manually on that part, can it be mixed between manual and auto route ?
And another question,
Why D0-D15 on RAM chip side are not in the same order with D0-D15 on CPU chip side.
CPU = 32 bits, RAM = 2 x 16 bit.
I’m thinking RAM D0-D15 = CPU D0-D15 and RAM D16-D31= CPU = D16-D31 ?
Thanks for that,
and auto route ?
chip side.
From what i can find there is no issue with swapping lanes so long as high and low are not swapped.
I would strongly insist you route high speed nets by hand only. Your dealing with very high frequency, crosstalk sensitive, controlled impedance and skew signals.
Ok, Had a better look at that Allwinners pinout, and i would say definitely on 4-6 layer. Almost all the center is taken up by the grounds and power planes, meaning you have your decoupling on the far side and happy days. Leaving you with roughly 4 balls deep at any point around the chip with plenty of missing pads to allow for some routing cleverness. which would be only 2 signal layers to escape. e.g. on a 4 layer, Signal - GND - GND / Plane - Signal. you would just make sure on the 4th your signals had a clear ground return path.
A part of me feels tempted to try and fan out this BGA on 1 signal layer, but I’m going to have to call it a night. Its so much easier at 4/4 rule.
I prefer taking it easy, 8 layers, reducing the difficulities and headache.
Anyway, I have the board with me but can not boot, do you have an idea why ?
Yes it is Opi.
The Power LED can not on at all, it’s quirky ?
I’m using 5V ATX power supply, so the power should be sufficient,
my DevBoard is Opi Lite.
