DB62 and Pin Receptacle Symbols
Do you have a physical connector?
If so then this is a easy way to test fit before ordering PCB’s:
Also, the visual stuff of the connector symbol in Eeschema does not have to look the same as the physical connector. Pins can be mixed up just as IC pins are usually grouped in logical functions. This can make drawing the schematic a lot easier. You will learn more tricks when you get more experience with KiCad.
