Database library file (*.kicad_dbl) generate for SQL based library
Hello Dears,
I developed kicad_dbl generator app for Altium db lib etc. Its Read SQL file, parse columbs, and create kicad_dbl file.
If you interest this app, I atached github link bellow.
P.S.: You must make changes for your SQL DB format
See you.
What sort of things can I use this for? What problems does it solve?
You can quickly compile Altium-based databases for kicad that you used to use or that you can find on the internet. In this way, it makes it easier for you to design by considering the materials you have in stock while designing.
That’s how I use it most. It also simplifies pricing.
Can it work in 2 directions?
Yes, you can use 2 directions or more (SAP,ERP etc.) if you don’t delete the associated columns on SQL_DB.
