Hi All,
is it true that I can’t create dashed rectangle with rounded corners in schematic?
I already tried combining arcs with lines as a workaround, but the dash pattern doesn’t look nice at the transitions.
Hi All,
This is with a radius 0.2". For smaller radius (0.1", etc) it doesn’t look indeed (you can’t change the dashed line properties)
The upper and the left end of a straight line is the start of the pattern, therefore “constant”. The lower and the right ends of lines depend on the line length:
Besides, it’s inconvenient to draw and to change.
