I am re-creating an old PCB so I am using polygons for the tracks, tracing an SVG. Two of the polygons have holes in them. On the original PCB there is no copper-to-hole clearance and no through-plating (single-sided board) but in order to make sure manufacturing of the PCB is successful/approved I guess I need to address this.
How can I cut a circular hole in the polygon shown in these screenshots?
If I right-click on the polygon and choose Create From Selection → Create Zone From Selection… then choose top copper then create a keep out area for copper fill it doesn’t seem to create a hole in the area.
I think converting the polygon to an area isn’t working - perhaps because I don’t have any nets?
If wanting a clearance between the Hole and surrounding Copper, you can:
• Put a filled circle in your SVG and place a smaller hole (or edge-cut hole in the same position).
• Can use a Solder Mask filled circle slightly larger than the Hole.
As I said, several ways to accomplish it… Also, may depend on if having the PCB made or making it yourself… If having it made, a Solder-Mask would be the preferred way.
The Gap/Clearance you want is about your design and is up to you…
EDIT:
Here’s example of SVG with Hole in it (by Subtract/Difference) done in Libre-Office.
Loaded into Kicad and drew a Hole on Edge-Cuts layer slightly smaller… You can see the Green PCB surrounding the hole…
