I’m looking for a way to create a custom rule that defines the clearance between a specific NetClass and filled zones. For example, I’m working on an RMII layout connecting a PHY to an MCU. I need the GND filled zone to be retracted from the RMII signals, but there are pins and vias close to these signals, which could cause DRC errors. I want this retraction to apply only to the RMII signals and not to any other signals, so I prefer not to use a default clearance.
I considered using a custom rule, but it ends up affecting other zones as well. I understand why this happens, but I’m unsure how to resolve it. Additionally, I would like the rule to apply based on the NetClass of the filled zone, rather than specifying its name.
In the example below, I want the GND fill to retract from the RMII signals. However, the power filled zone is also being retracted. I could address this by routing it differently, but I’d prefer a cleaner solution.
Rule:
(rule "RMII to Filled Zones clearance"
# Define a wider clearance to Filled Zones
(constraint clearance (min 0.8mm))
(condition " A.NetClass == 'RMII' && A.intersectsArea('GND_FILL') "))
PS: I found an example which uses “opt” and “max” for clearance, however I found only “min” as a valid option in the manual.
Thanks for your Help.
