I have DRC errors for courtyard overlapping of fiducials with other footprints.
I set the “Fabrication_Property” of these fiducial pads to “Fiducial, global to board”.
Also I took into account the negative clearance value:
This is my custom rule:
(version 1)
(rule allow_fiducial_courtyard_overlap
(constraint courtyard_clearance (min -100mm))
(condition "A.Fabrication_Property=='Fiducial, global to board")
What could be the reason not to work?
Regards,
Hannes
According to the manual, it should be . . .
"A.Fabrication_Property == ‘Fiducial, global to board’ "
not
“A.Fabrication_Property=='Fiducial, global to board”
. . . I think.
No, because the syntax check in the same window said “no errors found”.
And if you accidentally had faulty custom rules, this appears in the Layout window:
I’ve never used Custom DRC rules . . . it’s on my list of things to learn
I would try it, the quotes just look wrong to my eye in any case . . .
From the manual . . .
Don’t use thermal reliefs on heatsink pads
(rule heat_sink_pad
(constraint zone_connection solid)
(condition “A.Fabrication_Property == ‘Heatsink pad’”))
Thanks for the concern, but actually it both gives no errors weirdly. With just the preceding ’ and with encapsulating ’ ’
And both result in the same DRC error.
system
Closed
April 16, 2025, 12:05pm
6
