Custom footprints revisit
Hi all,
As far as I understand custom footprints are available in nightly builds for some time now.
  • Does anybody have info if they will make it into stable 5.0?
  • Also, to those of you who are using the custom footprint feature, are pads on internal layers possible?
  • I saw on the roadmap that one discussed feature of stable 5.0 should be getting rid of the footprint editor. does that mean that pads on inner layers will become a non-issue? This option is pretty important to folks who do high frequency boards.
Thanks ahead for any input you might have!
M
Are you referring to “Drop footprint edit mode.” ? http://docs.kicad.org/doxygen/v5_road_map.html#v5_pcbnew
If so, I believe that section discusses code changes that are internal to KiCad only. There might be some minor changes noticeable by the user, but I don’t think there is a plan to drop the footprint editor.
The roadmaps are written from the point of view of the developers, so you need to read between the lines a bit to understand the impact on users.
As far as I know, there are no changes in this area over v4.
