Custom Drawing Sheet : not loaded with design
Hello!
KiCAD 9.02, W11.
I have created a custom drawing sheet.
It is saved in a dedicated folder.
I can use it in my PCB design.
However, when I quit the project and reopen it, the drawing sheet that appears is not my custom one, but the regular one.
I cannot find an option to validate and fix this.
Do you have any suggestions?
Best regards,
Vincent
I have created my drawing sheet files (different for schematic and different for PCB (this one containing only small cross at 0,0 absolute position)) long time ago. Then I selected my files (separately in schematic and in PCB) in File-??? menu (sorry can’t be more specific now, as I have no KiCad here to check and don’t remember) - the place where you specify date, PCB name and revision to be used in drawing sheet.
Then I have never any problems with that, but I didn’t tried V9 yet.
I always start new design by copying and renaming an old one so since then (2017) I had never any need to think about drawing sheet files again.
Not sure if it helps, but may be…
Thank for message
I find the problem.
It’s due to the embedded file option (new in V9)
If I don’t use it and apply the path of the file it works.
If I use the embedded option it doesn’t work.
I need to check If I don’t use it correctly or if it’s an issue.
Best regards
Vincent
