Thanks, that is something, but it still requires a few actions (well, just two enters) in the export menu. Now if I could add a postprocessing script…
In addition to @marekr comment, your plugin code can run GUI’s, external App’s, Python codes…
Example runs some Python codes to run Stand-Alone python app’s. The other Plugin Icons run various Apps (including Java, SQL and Libre Office but not shown…).
These are run from the PCB plugins but, that doesn’t matter because you can run python coded (and other) App’s from the command field in Panel for the Generator…
