To develop KiCAD I cloned and built KiCAD (with 7.0.1 tag) under Debian 11.
But when I ran pcbnew, the python console showed up blank window.
I built kicad with wxWidgets 3.2 from codelite repo, and use python’s virtual env to install wxPython 4.2.
I configure build system by following command
cmake -G Ninja -DKICAD_USE_EGL=ON -DCMAKE_INSTALL_PREFIX=$(dirname $PWD)/debug_install -DPYTHON_SITE_PACKAGE_PATH=$(dirname $PWD)/debug_install/lib/python3/site-packages -DCMAKE_BUILD_TYPE=Debug ../../
-- The C compiler identification is GNU 10.2.1
-- The CXX compiler identification is GNU 10.2.1
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- KiCad install dir: <ROOT/kicad/build/debug_install>
-- Looking for malloc.h
-- Looking for malloc.h - found
-- Looking for iso646.h
-- Looking for iso646.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for strcasecmp
-- Looking for strcasecmp - found
-- Looking for strncasecmp
-- Looking for strncasecmp - found
-- Looking for strtok_r
-- Looking for strtok_r - found
-- Looking for malloc - found
-- Looking for math.h
-- Looking for math.h - found
-- Looking for C++ include cmath
-- Looking for C++ include cmath - found
-- Looking for asinh
-- Looking for asinh - found
-- Looking for acosh
-- Looking for acosh - found
-- Looking for atanh
-- Looking for atanh - found
-- Performing Test HAVE_CMATH_ISINF
-- Performing Test HAVE_CMATH_ISINF - Success
-- Looking for clock_gettime in rt
-- Looking for clock_gettime in rt - found
-- Looking for gettimeofday
-- Looking for gettimeofday - found
-- Looking for getc_unlocked
-- Looking for getc_unlocked - found
-- Performing Test COMPILER_SUPPORTS_WSUGGEST_OVERRIDE
-- Performing Test COMPILER_SUPPORTS_WSUGGEST_OVERRIDE - Success
-- Enabling warning -Wsuggest-override
-- Performing Test COMPILER_SUPPORTS_WINCONSISTENT_MISSING_OVERRIDE
-- Performing Test COMPILER_SUPPORTS_WINCONSISTENT_MISSING_OVERRIDE - Failed
-- Performing Test COMPILER_SUPPORTS_WDUPLICATED_BRANCHES
-- Performing Test COMPILER_SUPPORTS_WDUPLICATED_BRANCHES - Success
-- Enabling warning -Wduplicated-branches
-- Performing Test COMPILER_SUPPORTS_WDUPLICATED_COND
-- Performing Test COMPILER_SUPPORTS_WDUPLICATED_COND - Success
-- Enabling warning -Wduplicated-cond
-- Performing Test COMPILER_SUPPORTS_WVLA
-- Performing Test COMPILER_SUPPORTS_WVLA - Success
-- Enabling error for -Wvla
-- Performing Test COMPILER_SUPPORTS_WIMPLICIT_FALLTHROUGH
-- Performing Test COMPILER_SUPPORTS_WIMPLICIT_FALLTHROUGH - Success
-- Enabling warning -Wimplicit-fallthrough
-- Performing Test COMPILER_SUPPORTS_WRETURN_TYPE
-- Performing Test COMPILER_SUPPORTS_WRETURN_TYPE - Success
-- Enabling error for -Wreturn-type
-- Performing Test COMPILER_SUPPORTS_WSHADOW
-- Performing Test COMPILER_SUPPORTS_WSHADOW - Success
-- Enabling warning -Wshadow
-- Performing Test COMPILER_SUPPORTS_WSIGN
-- Performing Test COMPILER_SUPPORTS_WSIGN - Success
-- Enabling warning -Wsign-compare
-- Performing Test COMPILER_SUPPORTS_WMISSING_INIT
-- Performing Test COMPILER_SUPPORTS_WMISSING_INIT - Success
-- Enabling warning -Wmissing-field-initializers
-- Performing Test COMPILER_SUPPORTS_WEMPTY_BODY
-- Performing Test COMPILER_SUPPORTS_WEMPTY_BODY - Success
-- Enabling warning -Wempty-body
-- Performing Test COMPILER_SUPPORTS_WREORDER
-- Performing Test COMPILER_SUPPORTS_WREORDER - Success
-- Enabling warning -Wreorder
-- Performing Test COMPILER_SUPPORTS_WMISMATCHED_TAGS
-- Performing Test COMPILER_SUPPORTS_WMISMATCHED_TAGS - Success
-- Enabling warning -Wmismatched-tags
-- Performing Test COMPILER_SUPPORTS_WIMPLICIT_FLOAT_CONVERSION
-- Performing Test COMPILER_SUPPORTS_WIMPLICIT_FLOAT_CONVERSION - Failed
-- Performing Test COMPILER_SUPPORTS_WPSABI
-- Performing Test COMPILER_SUPPORTS_WPSABI - Success
-- Disabling warning -Wpsabi
-- Configuring KiCad for the wxGLCanvas EGL backend
-- Found OpenGL: /usr/lib/x86_64-linux-gnu/libOpenGL.so
-- Found OpenGL EGL library: /usr/lib/x86_64-linux-gnu/libEGL.so
-- Found GLM: /usr/include (found suitable version "0.9.9.8", minimum required is "0.9.8")
-- Found ZLIB: /usr/lib/x86_64-linux-gnu/libz.so (found version "1.2.11")
-- Check for installed ZLIB -- found
-- Found CURL: /usr/lib/x86_64-linux-gnu/libcurl.so (found version "7.74.0")
-- Found PkgConfig: /usr/bin/pkg-config (found version "0.29.2")
-- Checking for module 'cairo'
-- Found cairo, version 1.16.0
-- Found Cairo: /usr/lib/x86_64-linux-gnu/libcairo.so (found suitable version "1.16.0", minimum required is "1.12")
-- Checking for module 'pixman-1'
-- Found pixman-1, version 0.40.0
-- Found Pixman: /usr/lib/x86_64-linux-gnu/libpixman-1.so (found suitable version "0.40.0", minimum required is "0.30")
-- Found Boost: /usr/lib/x86_64-linux-gnu/cmake/Boost-1.74.0/BoostConfig.cmake (found suitable version "1.74.0", minimum required is "1.71.0")
-- Found Freetype: /usr/lib/x86_64-linux-gnu/libfreetype.so (found version "2.10.4")
-- Found the following HarfBuzz libraries:
-- HarfBuzz (required): /usr/lib/x86_64-linux-gnu/libharfbuzz.so
-- Found HarfBuzz: /usr/include/harfbuzz (found version "2.7.4")
-- Found Fontconfig: /usr/lib/x86_64-linux-gnu/libfontconfig.so (found version "2.13.1")
-- Checking for module 'ngspice'
-- Found ngspice, version 34
-- Found ngspice: /usr/include
-- Found OCC: /usr/include/opencascade (found version "7.5.1")
-- Found OpenCASCADE Standard Edition version: 7.5.1
-- ++ OpenCASCADE Standard Edition include directory: /usr/include/opencascade
-- ++ OpenCASCADE Standard Edition shared libraries directory: /usr/lib/x86_64-linux-gnu
-- Found SWIG: /usr/bin/swig4.0 (found suitable version "4.0.2", minimum required is "4.0")
-- Found PythonInterp: ROOT/kicad/venv/bin/python3 (found suitable version "3.9.2", minimum required is "3.6")
-- Check for installed Python Interpreter -- found
-- Python module install path: ROOT/kicad/build/debug_install/lib/python3/site-packages
-- Found PythonLibs: /usr/lib/x86_64-linux-gnu/libpython3.9.so (found suitable version "3.9.2", minimum required is "3.6")
-- pybind11 v2.9.2
-- Performing Test HAS_FLTO
-- Performing Test HAS_FLTO - Success
-- Found wxPython Phoenix 4.2.0/gtk3 (wxWidgets 3.2.0)
-- Found wxWidgets: -L/usr/lib/x86_64-linux-gnu;-pthread;;;-lwx_gtk3u_unofficial_gl-3.2;-lwx_gtk3u_unofficial_aui-3.2;-lwx_gtk3u_unofficial_html-3.2;-lwx_gtk3u_unofficial_core-3.2;-lwx_baseu_unofficial_net-3.2;-lwx_baseu_unofficial-3.2;-lwx_gtk3u_unofficial_propgrid-3.2;-lwx_baseu_unofficial_xml-3.2;-lwx_gtk3u_unofficial_stc-3.2;-lwx_gtk3u_unofficial_richtext-3.2 (found suitable version "3.2.0.1", minimum required is "3.2.0")
-- Found Doxygen: /usr/bin/doxygen (found version "1.9.1") found components: doxygen dot
-- Found UnixCommands: /usr/bin/bash
CMake Warning (dev) at thirdparty/argparse/CMakeLists.txt:10 (option):
Policy CMP0077 is not set: option() honors normal variables. Run "cmake
--help-policy CMP0077" for policy details. Use the cmake_policy command to
set the policy and suppress this warning.
For compatibility with older versions of CMake, option is clearing the
normal variable 'ARGPARSE_INSTALL'.
This warning is for project developers. Use -Wno-dev to suppress it.
-- Module support is disabled.
-- Version: 9.0.0
-- Build type: Debug
-- CXX_STANDARD: 17
-- Performing Test has_std_17_flag
-- Performing Test has_std_17_flag - Success
-- Performing Test has_std_1z_flag
-- Performing Test has_std_1z_flag - Success
-- Required features: cxx_variadic_templates
-- nanodbc version: 2.14.0
-- nanodbc compile: C++14
-- nanodbc feature: ODBC Version Override - OFF
-- nanodbc feature: Disable async features - OFF
-- nanodbc feature: Enable Unicode - ON
-- nanodbc feature: Enable Boost - ON
-- nanodbc feature: Enable SQL_NO_DATA bug workaround - OFF
-- nanodbc build: ODBC on Unix - unixODBC
-- ODBC compile flags: -I/usr/include -DHAVE_UNISTD_H -DHAVE_PWD_H -DHAVE_SYS_TYPES_H -DHAVE_LONG_LONG -DSIZEOF_LONG_INT=8
-- ODBC link flags:
-- Checking for module 'gtk+-3.0'
-- Found gtk+-3.0, version 3.24.24
-- S3DSG version: 2.0.0
-- Found Boost: /usr/lib/x86_64-linux-gnu/cmake/Boost-1.74.0/BoostConfig.cmake (found version "1.74.0") found components: unit_test_framework filesystem system
-- Found wxWidgets: -L/usr/lib/x86_64-linux-gnu;-pthread;;;-lwx_gtk3u_unofficial_gl-3.2;-lwx_gtk3u_unofficial_aui-3.2;-lwx_gtk3u_unofficial_html-3.2;-lwx_gtk3u_unofficial_core-3.2;-lwx_baseu_unofficial_net-3.2;-lwx_baseu_unofficial-3.2;-lwx_baseu_unofficial_xml-3.2;-lwx_gtk3u_unofficial_stc-3.2 (found suitable version "3.2.0.1", minimum required is "3.0.0")
-- Configuring done
-- Generating done
-- Build files have been written to: ROOT/kicad/build/t
I ran the pcbnew via KICAD_RUN_FROM_BUILD_DIR=1 ./pcbnew/pcbnew
