Hello everyone,
I´m doing a project and thinking about doing a custom PCB, therefore I´m designing the board on Kicad.
I had to design a custom footprint for my audiojack, however I´m not sure if I selected the correct pads.
The width of the part´s connector is roughly 1mm, therefore I put a hole size of 1mm on the pad settings.
My jack is similar to the Ledino available on Kicad, however this one uses an oval and rectangular pads.
Should I copy Ledino´s or keep with circular pads?
I´m attaching pictures of my pads and the part itself.
Thank you for reading!
