Crystal footprint
Im restarting my Kicad venture. Have loaded standard/default kicad. There are lots and lots of components in libs. However i miss what I would suspect very common component, a crystal like HC49-S och equiv. 2 pin 4.88 mm, component and footprint. Why not in standard libs. Any notion where I could find ? (no big deal doing myself, but strange not avail)
Both symbols and footprints for crystals are there, I’ve been using them for ages, you just haven’t looked hard enough. Try a search. Not at computer so can’t show you screenshots.
Please always link to a data sheet for the component in question.
Right, that one for 2pin I found, no foot.
eg;
your most probably right, Ill try again. but at first attempt got me the above shown entry for 2pin…
Except for the height, it is a HC-49-U. You’ll have to live with a clumsy 3D-model.
But you asked for a footprint. That doesn’t include a 3D-model. :wink:
Hi all, sorry to have bothered. Didnt see the scrolldown for “no default” footprint. Old and blind :wink:
thx for support.
Actually and improvment could be to state “choose crystal” och “further select”, instead of “no default”,
would have put me on track… :slight_smile:
For a generic symbol No default footprint is exactly what is meant. If it were a symbol which has a footprint already assigned in the symbol, you would get something like this:
This is how the items in the symbol library work in KiCad, a default footprint can be assigned. If not then you will have to do the assignment before proceeding to the PCB. The dropdown is a convenience to do the assignment at this point.
PS: Incidentally somebody can gain some karma cheaply by copying the HC49U vertical footprint to HC49S vertical, deleting the 3D model field and submitting a MR to the GitLab KiCad footprint library.
