Hello question I am looking for screen crossing line configuration?
It is not cross pointers
Greetings from Mexico
pointers no. I want it active, I want the fixed screen cross X0 and Y0 white line
I’m not entirely sure what you want, but if you want some simple static lines at fixed locations, you can even make them a part of the paper itself (Some people remove the paper outline and title block and only use an origin mark for the paper itself).
Another option is to create a custom footprint which has your lines, and then lock it in whatever location you prefer.
If I had always had a fixed cross screen for about 2 years and a half
I formatted my computer, deleted the Kicad configuration, the cross line is no longer there, I no longer remember where it was active, it was always fixed cross
Version 7.0.10
It’s clearer @00:44 where you can see these lines are much longer then the paper size. Both the symbol and Footprint editors also have an “infininte” cross at their origin.
I’ve looked a bit though the menu’s and through the manual, but I do not know how to enable this function in the PCB editor.
Perhaps you (or someone else) modified the default template and added the two lines ?
screen 4 lines cross fixed can’t find several tried configuration
